HB212 Garden Tractor
reedski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reedski Quote  Post ReplyReply Direct Link To This Post Topic: HB212 Garden Tractor
    Posted: 21 Aug 2015 at 8:38pm
I need ideas on problem with my HB212, I am a retired engineer and have exhusted my ideas.
My tractor is super sensetive as the hydro control is moved. When the unit moves it has a periodic "surge" the rpms remain the same. I can take it out on the street af full throttle and speed, it works without surging. Problem has become progressivly worse over several years
I have:
Checked for leaks
Checked and replaced belts
Eliminated carburation probs
Replaced the Hydro filter
Verified positraction adjustment
Anybody had this prob? Things to try ?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 4:16am
air in the system? pump going out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 5:28pm
was thinking about this all last night...bet you have some linkage that's worn a bit!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 10:29pm
Have you checked the bolts that connect the bevel gear box to the frame tunnel? If they are getting loose you could have intermittent belt slip.
This page was generated in 0.365 seconds.
