HD4 Serial Number
Buck1278 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buck1278 Quote  Post ReplyReply Direct Link To This Post Topic: HD4 Serial Number
    Posted: 20 Aug 2015 at 7:50pm
Hi, new to the forum. I'm selling my dozer, and the buyer needs the serial number to secure the loan. The badge on the engine block is missing. Are their any other serial numbers on the dozer that can help identify his particular machine? Any help would be appreciated. Thanks.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 10:00pm
SHOULD BE STAMPED INTO THE FRAME UNDER THE FRONT GRILL. I HAVE AN HD4  DOZER AND LOADER AND BOTH OF THEM ARE STAMPED ON THE FLAT LIP OF THE TORQUE HOUSING WHERE IT BOLTS TO THE BACK OF THE ENGINE JUST BEHIND THE OIL FILTER. CHECK IT OUT AND GET BACK TO US.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buck1278 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2015 at 1:31pm
I will check it out tomorrow. Thanks for the info! I'll pass along what I find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buck1278 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2015 at 6:16pm
I wasn't able to find the numbers. Maybe I was looking ing the wrong spot. Would it be possible to get pictures of where I should be looking exactly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buck1278 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2015 at 8:20pm
I wasn't able to find any numbers. Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2015 at 9:07pm
At the bottom of grill just inside IIRR. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2015 at 9:56am
hey tracy , look on the side of your converter housing next to the oil filter where it fits agaiinst the back of the engine and see if you have HD and serial # on yours. both of mine are there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 8:40am
I CAN SEND YOU SOME PICS OF WHERE THE SERIAL # LOCATION COULD BE , BUT I NEED YOU TO PM ME YOUR E-MAIL AS I CANNOT POST PICS TO THIS FORUM.
This page was generated in 0.238 seconds.
