wc engines
ALLIS NUT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLIS NUT Quote  Post ReplyReply Direct Link To This Post Topic: wc engines
    Posted: 20 Aug 2015 at 12:23pm
can you please name some of the changes the wc engine had from the first unstyled wc with the allis engine to the last styled wc had? thank you in advance.
TERRA TIGER D-19 WC UNSTYLED WC STYLED WD-45 UC,rc,190,ca,7790,B10
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 1:17pm
Mag drives were different, manifolds changed, compression ratios...wasn't alot.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 1:56pm
Weren't a very few early 'W' engines that had slightly smaller crankshaft bearings? Not the Waukesha engines, though..
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 3:07pm
Not that I've heard of. Should have been the same from early 201 til the D17 came out and they went to a larger main bearing
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 3:22pm
The early ones did have smaller bearings.  When was the head changed to have the 3 smaller bolts down the right side?  Few real minor things like cast valve covers/pans, the mag was changed.  Think they had 2 different carbs.  Air cleaner was changed at styled.  But as far as the engine itself goes, the crank is all I can think of other than the head bolts.  You can get on AGCOparts.com and look for serial number changes.
AaronSEIA
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 5:26pm
Rockers and valve retainers where also different
nonetheless ,still dead.
