13,500# farm stock allis?
ACman75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Topic: 13,500# farm stock allis?
    Posted: 20 Aug 2015 at 10:40am
Hey I'm interested in what allis would be a good tractor for a farm stock 13,500# class. 12mph 3,000 rpm. Thanks for your help
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 4:30pm
our 210 weighs 11500 with no water in rear tires runs in the ten mph range and she still earns her keep in the field when we need her to
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 6:20pm
Yup a 210 will work out real nice for ya
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 6:32pm
 What would be the best choice in 7000 series AC,s  ?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 7:35pm
I'd think a 7060 or 7080 would be sweet.  I think the 7080 was counterbalanced, so it might take the extra rpm better.  Find a way to make the torque limiter hang on and you should be good to go.  Shouldn't be too hard to get any of the 7000's down to 13,500.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 7:39pm
a 210 with 7000 sheet metal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 7:50pm
Yup a 210 with 7000 series metal would be perfect, 7000 series had all the Pd clutches, and the torque limter on the main clutch to cause slipping,,, 210 all gears after the engine clutch
Edited by DougG - 20 Aug 2015 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 8:07pm
Thanks guys for the help! We have a 200 but use it a lot. With the smaller motor it wouldn't work to well anyways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 8:59am
How would a D21 do for this class?
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 9:51am
Pretty heavy for a 21. Mine does better in lighter classes. Most 21s are pretty expensive to make a puller . 7000 series a lot cheaper to buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 2:44pm
So I've came across a 7060 at real good price. How will it do in this class with the tranny and all? Trans and clutch seem to be in very good shape. And what could be done with tractor to give it a little more hp for now. Trying to stay on a budget for now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 2:03pm
Got us 210! So How much trouble would it be to put 7000 series sheet metal on 210?
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 3:53pm
used to pull our 7040 with great results
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 4:17pm
unless a tree has fallen on the hood  and grill of the 210 I would not bother
Edited by Beirnesy - 02 Feb 2016 at 10:13pm
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 7:07pm
Now 4500 will make you compete in that class with a 210 3500 on pump line and injectors and 1000 on a s362 turbo and hang on. Not trying to discurage you just letting you know what it takes to compete in my area anyhow. Your area may be different also speed limit makes a huge difference what's comen in your area 10 12 18 mph or open speed limit classes will help .
Just reread 12 mph the ih guys are still strong in that range if possible do pump lines and injectors also turbo you won't be sorry
Edited by 7040 - 02 Feb 2016 at 7:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 10:22pm
Thanks 7040 and Yes it's seems to be a pretty strong class. We are planning on bigger lines, injectors, pump and turbo. And a good clutch.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2016 at 9:48am
I remember years ago JoeIA's family ran a late model 7060 and had great results with it.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 9:07pm
Just as well get the power director out of it. Spend the money now, once you get enough power to compete, you will not be able to hold it in your PD.
      IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 9:17pm
I believe there has been some confusion here. We are building 210 for these class. I am looking for a good clutch though for farm stock pulling, maybe a steel flywheel? What's best to use in a single disc setup?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2016 at 6:34am
I've never seen a steel flywheel for a single disc. I will be taking my dual disc out, and selling it, since I bought a different one and set it up for the big input shaft.
