kohler m20
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Topic: kohler m20
    Posted: 18 Aug 2015 at 8:56pm
I have deutz allis 1920 developed severe vibration over 2 yr. time replaced u joints on pto shaft from eng to trans no change if anyone thinks or knows vibration could b coming from m 20 kohler
716 917 918 1920 d17 6080
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2015 at 6:59am
Yes or bad motor mounts, bent driveshaft. Any number of things. Try running it with drive shaft off. If motor is moving around a lot its probably mounts if engine sounds normal and is running smoothly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 11:12am
thanks for advice , turns out it is the splined yoke that goes on to the transmission input shaft loose enough to let shaft wobble . guess i'll pull motor again and try to find parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 6:47am
Had that happen on my 716H one year plowin' snow. Started feeling a vibration that wasn't there before. Immediately went down under to check things out. Eventually found the bolts had loosened on the front yoke and it started egg shaping out the fiber disc in there. Had some spare parts from another 716H I had and used one of the discs from that. Problem solved. Made sure I checked those yokes on occasions for tightness...
Steve@B&B
This page was generated in 0.079 seconds.
