Charging 8V Battery
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Charging 8V Battery
    Posted: 13 Apr 2010 at 3:19pm
I have an 8v battery for one of my tractors and would like to charge it off the tractor. I've got a simple (read: cheap) charger that offers 6 and 12 volt options, both at 6 amps. The 6v setting would seem to lack the volts to get to a decent charge on it, and using the 12v setting causes the internal regulator to pop on and off rapidly.
Are there any suggestions on getting this done as well as possible? Thanks much!
WC, CA, D14, WD45
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:00pm
Your 6 volt gennie should charge the 8 volt battery nicely. You may have to adjust your 3rd brush on the gennie.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:05pm
A three brush generator has NO voltage regulation. The third brush gives current limiting or current regulating. It only knows to charge at the full current, though that current is probably modified by the light switch adding resistors or removing them from the field circuit. No need for third brush adjustment when going to the abusive 8 volt battery to get around poor connections in the starter circuit.
Gerald J.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:19pm
Jeff, thanks for the link. That gadget could be an option.
Appreciate the other input......though it's been a while since I've been accused of being abusive! I do pay attention to grounds - they get cleaned 1-2 times a season.
Edited by Dave(inMA) - 13 Apr 2010 at 4:22pm
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:35pm
My "new" G has an 8v battery and it was low when I got the tractor. I just hooked up the charger and put it on 6 V and left it overnight. It has worked fine. I need to look at the charging system when I get to it but the battery spins it over just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 4:46pm
Not only grounds, but ALL starter circuit connections. Battery posts, grounds, wire connections to the starter switch or solenoid and the starter. Starter brushes do wear down and break wires off. Starters wear out bearings (bushings) and let the armature drag on the field poles. That really kills a starters output because the magnet forces that make the armature spin pull it to the field poles too. That and the side thrust from the gears wears bushings. Not to forget sturdy battery cables. Wallyworld kiosk cables are as good as a broken cable on a 6 volt system, there's not nearly enough conductor.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:17pm
Gerald, That last post was better. The other one could make a person mad
We'll leave the mad people to the political section.
Now there you will find some ugly mad folks.
Where was I:
I had a D-17 that would not turn over with a brand new battery.
I took the whole electrical system apart including the starter and cleaned everything.
It then turned over like the day it was new.
Your advice on this subject is perfect.
Edited by Jeff Z. NY - 13 Apr 2010 at 6:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:27pm
When charging some small batteries for real slow charge I used a old train transformer .
I hooked one lead through the variable voltage lead and used the pointer to set the amp rate and common lead out to bat. Also have used a large coil of wire to vary the resistance to cut charge rate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 7:21pm
Interesting points. As it happens, that particular tractor, a C, has heavy duty cables (NAPA) and a rebuilt starter. It's due to have the surfaces that provide ground for the starter polished as well as the ground post connections before the battery goes back in, but at the moment the electrons in that battery are pretty quiet. I'm suspecting that it may have sulfated over the winter...... I think the battery maintainers are a good idea for equipment that sits - my motorcycle was on one all winter, and that battery is in great shape.
WC, CA, D14, WD45
