electric fuel pump |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: electric fuel pumpPosted: 08 Aug 2015 at 5:07am |
Any of you use a electric fuel pump on your gas pullers?
benefits outway added complication?
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
DrAllis
Posted: 08 Aug 2015 at 6:12am |
Generally speaking, unless you are running way more RPM's than stock, there is no need for an electric fuel pump. An electric fuel pump doesn't automatically make the engine have any more HP. The engineers designed the fuel system to be able to flow more gasoline per hour than the engine can burn. Now, if you have a rubber gas line with a droop in it......that isn't good. The fuel supply line should always be in a straight line from the fuel tank to the carb. More fuel in the tank increases fuel flow per hour. Using a larger than stock carb, I have drilled out the hole in the needle and seat to insure enough fuel flow for a gravity supply system to use. Most Antique Clubs don't allow an electric fuel pump.
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 08 Aug 2015 at 9:12am |
Not sure if it did any good but I went to 3/8 line and a 1/4 turn ball valve on my WC with a high flow filter for a V8. At least I know I have good flow lol
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 08 Aug 2015 at 12:10pm |
I used a fuel pump for 5 years. Had to replace it 3 times. Took it off. And used 3/8 black pipe to make my down and straight parts. And gray 90 degree corners. Then a 3/8 high flow fuel line and filter. Haven't starved for fuel yet.
