LOOK WHAT FOLLOWED ME HOME!
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Topic: LOOK WHAT FOLLOWED ME HOME!
    Posted: 12 Apr 2010 at 10:29pm
I picked this M&W dyno up this weekend. Needs a litle paint, and got the manual with it. I thought i would share some pictures.
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 12:55am
Used one of those at our local BOCES school when I was in highschool. You can really make a tractor talk with one of those! Make sure you have the water hooked to her as they can get very hot!
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:12am
How much HP can it measure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 7:23am
My boss bought one of those at a sale several years ago. He brought it to the shop to "fix" and we found all the clutch plates burned up and a leak in the tank. He had a guy fab up a frame with a flat pulley on it so we can run it with a flat belt. It works good for our show if someone wants to dyno his Rumley Oil Pull  or Steam engine.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 10:19am
How does the dyno work?  Is it a pump that is deadheaded? Always heard of them, but have never seen one.................O_O
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 12:22pm
This dyno measures up to 90 to 100 HP. I don't know how to run it. My buddy has run a couple at different ac dealerships. So, I'll be learning this summer when the crops are in. The gentleman that i got it off of said it works great. He upgrated to a 400 or 450 HP dyno. I'm sure I'll have lots of fun with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 5:13pm
Osage, basically there are a stack of brake pads with disc's in between. You crank the brakes tighter to make the tractor work harder. Everything is emersed in water and the water flows through to keep things cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 5:24pm
I think the clutches are in oil and the oil runs through a cooler with the water running through it.
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:34pm
that is awesome!!!  I would love to have one!
Andrew Gubbels
Andrew Gubbels
Gubbels Restoration
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 5:52am
Great find Bryan. I have one just like it except mine is factory remanufactured. There are no clutches in that model. The handwheel in the front restricts the oil flow from the pump, producing more resistance. The water flows through a heat exchanger submergerd in the oil reservoir.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:38am
Chad is right on on how that model works, basically  as the turn down the wheel you dead head the pump and pressure increases, since the pump is constant volume( displacement in gpm) , you  measure the pressure, then calculate the horsepower from the pressure and flow, this is wha the little chart that is witht hem does., the water is just used to cool the oil
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 9:07pm
I bought a used P 400 about 20 years ago. Great to have around. Measures 240 hp @ 1000 rpm pto. We rest the loader bucket on the one wheel when were run at the high end. I've seen the needle around the bottom more than once.
