WD w/ mounted sickle mower
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Topic: WD w/ mounted sickle mower
    Posted: 12 Apr 2010 at 8:08pm
I hope to go look at a rear mounted mower for my WD next weekend.  I do not know what model it is yet, but the fellow is supposed to send me some pictures Friday.  Can you guys post some pictures of rear mounted mowers on WDs?  Anything in particular to look for?  I know next to nothing about sickle mowers in general, and even less about mounting one on a WD.  Educate me please!
Thanks,
Adam
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 9:29pm
Adam, Here is a 80-R on a WD45 if you look at the mounting bracket on the tractor it's not a snap coupler like the # 7 mower is. both #80-R and #7 are good mowers the #80-R is newer than the #7. The old # three mower is a Pittman drive and will not take mowing at a hi or low angle on the bar like the #80-R and #7 will.
If you need more INFO just PM me about it.
Don
Edited by Don(MO) - 12 Apr 2010 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 9:30pm
Here is a pic of a #80-R. forgot to post it before. Sorry.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:46pm
Thanks Don!
I see a lift link on the right lift arm - Doe this on lift arm lift the entire mower up and down?  Is there an automated way to raise and lower the bar, or is it put in the mowing position manually?
Anybody got a picture of a #7 mower they could post or send me?
Thanks,
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:30pm
Originally posted by NCAllisnut NCAllisnut wrote:
Thanks Don!
Thanks,
Adam
Adam, Yes the right lift arm is all that lifts the mower up on a 80-R, It is the lift and controls the mower height too. I will post a shot of one of my #7 mowers tomorrow for you. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:35pm
Her is a shot of the shoe on the inside of the mower there is a shoe on the out side of the bar the two shoes are how you set the mower's ride hight. this mower is set to the lowest setting. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:12pm
Thanks Don!
Any major advantage of the 80-R or the #7?  How do you raise and lower the cutter bar from cutting to road position?
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:31pm
Thanks Don!
Adam
To me the #7 is easier to install than the 80-R. They both require you to get off the tractor and raise the bar and then put the rod into the bar for transport.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:35pm
I said that wrong! You haft to put the rod on the 80-R, The #7 has a bracket that holds the bar for transport.
Don
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:36pm
Not sure what model we had on the D14.  When it lifted the bar would raise a up at an angle.  There was a cable that did that as I recall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:39pm
Gotcha, I think I am begining to get it.  The tractor lift lets you adjust the mowing heoght, but you have to manually raise the bar to go down the road.  Close?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:44pm
On some the bar would also tilt up somewhat to clear an obstacle in the field  but you had to lift it manually to fold up all the way for transport.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:51pm
I just looked back at my pics and I don't have a shot of one raised up, Sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:14pm
Thanks for all the info Don - I'll post a picture when I see what I may be getting.
Adam
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:46pm
I have one just like the one in Don's pictures that I would part with if anyone is interested. Located in SW Mo.  417-850-4532
walterfd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walterfd Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:07pm
Hi Adam,
Do you still have that allis 80R mower or have you already parted with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote walterfd Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:11pm
Hi Rick,
I live in Charlestown Indiana and I saw your post about an 80R mower.  You wouldn't happen to know about one for sale in our neck of the woods would you?   A #7 would be ok too.
Thanks.
Doug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:17pm
Walter,
I still have the mower.  Give me a call if you want to talk about it.  I am located in the Joplin MO area.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:47pm
I have one of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 9:00pm
You can store it at my place if it is in your way!
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote walterfd Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 10:29pm
Hi Rick.
It looks like this would work with my snap coupler linkage.  I can't see the top of the cutter bar in the picture, how is the shoe on the outside end and the grass board?
Is it in working order?  Have you been usingi it lately?  Thanks for the Post.  I'm in southern Indiana. Where are you located?
My phone number is 502-396-1490.
Thanks. Doug.
This page was generated in 1.148 seconds.
