couple G questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: couple G questions
    Posted: 12 Apr 2010 at 7:44pm
Is there a place for a temperature gauge? Is the governor supposed to be set up similar to the other models? IE 1/16 inch pressure on idle screw when shut down. My, oops Liz's G looks like it might have too much water and it starts to blow out the overflow after about 5 minutes of running. The governor doesn't.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:16pm
Niether of my G's have a temp. gauge and I can't help with the governor.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:29pm
if you are filling the radiator to the top, it will blow off as thewater expads as itr heats. it is normal for the level to be below full after it has been run. The G doesn't have a gauge or a water pump, so it will tend to run on the hot side. It uses hydro-syphen to cool it. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:36pm
Ok thanks guys. Now if I can get the little flathead to govern like an Allis, I'd be tickled pink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:49pm
The rad was full to the top when I bought the tractor. I thought that might be all that was wrong but I suppose it wouldn't hurt to back flush the thing for a while.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 9:03pm
Charlie, just be sure there's enough water to cover the top neck. the water must be able to make the loop or she's soon to be dead. Check your e-mail in a moment, some reading material (manuals) on the way on the G
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 1:31am
Thanks Joe. Your the best.
