'59 D17 For Sale
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: '59 D17 For Sale
    Posted: 12 Apr 2010 at 5:23pm
D17 puller for sale   906 478 4274
Edited by Gary in da UP - 19 Jan 2012 at 5:14pm
rangerwalker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rangerwalker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 3:10pm
i have a '59 D17 (gas). What's the stock hp rating on these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 5:54pm
Nebraska test says 52.72 HP with power steering at 1650 rpm full load.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 7:01pm
Gary; I see your hitch ring is out past your tires. Is that the secret to get a D17 to pull. I have seen some of your videos with the wheels in the air. I found a youtube video of me pulling one of our our D17s at Tweed Ontario this year. As you can see it does not transfer any weight. It is pulling in the 5500lb class with 16.9x28 rears. Our hitch point is 20" high and 18" from the centerline of the axle.
http://www.youtube.com/watch?v=2w_xj-T7iV8&feature=related
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 10:07pm
Gary, I forgot to ad, I wish I had bought this tractor off of you instead of building my own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:02am
Brian, you need to fine tune your tire pressure first of all , your not transferring weight 'cuz you lack traction .... too much spinnage. Tires need to wrinkle a bit. A longer drawbar may help. I never pulled mine with a wide front, I went right to a narrow front, and stripping off weight where ever I could, seldom add weight to the front, depends on the track.
What gear were you pulling in in the video?   1st?  I noticed the power director shift, I think you would have pulled better  leaving it in hi range . I pull in 2nd low, , several pulls at 5500 on a good power-stealing track , I should have tried hi 1st.  I might have done better. Traction was not an issue, nor was power.... tire pressure, and weight / balance  were my challenges.  This was a short season of pulling this year for me and made a lot of changes so there were things to sort out. Thats the bad of pulling, you can't try to catch the leader on the next lap.
PS it is still for sale at $4500. usd, I have had some interest, but  no one has committed. I would prefer to not sell it locally, I wouldn't want to pull against it.
Edited by Gary in da UP - 20 Jan 2012 at 1:28pm
This page was generated in 0.352 seconds.
