Fine Grading with the "D" special
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: Fine Grading with the "D" special
    Posted: 12 Apr 2010 at 4:42pm
It was a fine day to do some fine grading with a fine machine. This my friend Ross Dryden's D special. It has all the goodies including the range transmission. It was the one on the front cover of OAN at the GOTO in Milton last year.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 1:05am
Looking good Calvin. Ross has sent me several pictures of this machine as well as some others in your area. I am getting close to finishing some modifications to my D grader so that it can start to earn it's keep. I have added power steering using components from an sp combine and a separate ps pump. I am about to add a heel and toe foot throttle to make it easier to double clutch when shifting up or down when travelling on the road. I am still trying to find an angle gear drive for the power circle. This worm gear angle drive is common to the D graders, the M65 that followed and the FA65's so if anyone knows of a parts unit of any of these models with a good angle drive please send me an email. Thanks, Don
ron mi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ron mi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 5:41pm
I have the same grader with the hi -lo range trans only mine is  in work clothes. Good graders ron mi.
AllisTime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisTime Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 1:33am
Calvin, What size tires do you have on the drive wheels,,,Thanks, Wayne.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 4:04pm
The grader has 8.25 x 20 tires all around.
This page was generated in 1.359 seconds.
