444 Baler knotted brake
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Topic: 444 Baler knotted brake
    Posted: 29 Jul 2015 at 9:13am
Can anyone help me please?? Was bailing with 444 and D17 when Baler started breaking flywheel shear pins. Timing is good, makes perfect knots an bales (when working). Problem is after tying a bale, needles will fall from retracted position back into bale chamber-causing plunger stop to engage, plunger then contacts stop and breaks shear pin. I believe knotted brake is totally worn - no adjustment left. Agco dealer says obsolete and out of stock. Does anyone know where I may find a knotted brake ( # 543546 ). Or is there something else that should needles in retracted position??? Thanks to all....Dan
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2015 at 10:27am
You might take the brake off and go to a New Holland or another dealer to see if they will fit.
Tom
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2015 at 10:35am
I put new brake pads on my 444 about 15 years ago and they were obsolete then. I took the brake assembly to a clutch rebuilder and he made some brake pads for it and riveted them on. He didn't charge much and it has worked perfect ever since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2015 at 10:45am
Might be something Rick Corder (aka Rick) here could do as he relines brakes along with doing clutches?  PM him.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2015 at 11:01am
   I can help you out.  Be thankful that the plunger stop was up to date....Call me.....Dale
Orangereborn
Dale Schafer
964  192nd Ave
New Richmond, WI 54017
715-247-3079
Cell 715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2015 at 2:33pm
You should have a local shop that can add brake lining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2015 at 7:13pm
Thanks to all who responded. I followed suggestion and found a heavy truck shop and got brake rebuilt (also included a extra set of linings all for 25 bucks). Also think I found real source of problem. Large castle nut on left end of knotter shaft was loose, causing roller to slip past dog in clutch housing. Due to rain, not able to test it out...but am gaurdedly optimistic...Thanks again (I love to keep the old orange going)...Dan
