Grass Work: Tractor or ZeroTurn Mower?
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Topic: Grass Work: Tractor or ZeroTurn Mower?
    Posted: 12 Apr 2010 at 10:15am
I was home this past weekend to visit my mom and dad and work on one of the tractors and he started talking about how much he wanted a Dixie Chopper.  I suggested a 3pt finishing mower because it would be cheaper.  I have seen good used ones for between 500 and 1,000.
Basically there is so much grass that needs to be cut it takes him literally two solid days on the Snapper; not counting all the pasture/woods that has to be cut.
I was thinking that it would also be more economical with the diesel.
What's everyone’s take and/or what are you using?
Thanks.
WC Fields(N_ILL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Fields(N_ILL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:27am
I use a Hustler zero turn with a 60" deck. I mow our 6 acres in just over 2 hours. It does an excellent job and I would get another if I would ever wear it out.
37 WC   49 WF   53 WD   67 D15
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:35am
Also, how large of a finishing mower would a 46PTO HP tractor run?  I was thinking a 5 foot would be like there was nothing behind it.
Ron(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:47am
If he already has good tractors, it's a no brainer, get a mounted mower.A 5 footer would be all he would need. trim cut with the Snapper. He really doesn't need a humongous big mower, because the bigger the clumsier.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:52am
But if he drives a zero-turn he will love it.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:54am
depends on the number of obstacles. I use a rear mount 5' mower on my CUT, but if I had a lot of trees then a ZTR would be my first choice.
Also you have to factor in if you have live PTO or not
Charlie
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:58am
I used the Landpride 2584 this weekend behind a WD. 7 foot was all the WD wanted, but it did well where the grass wasn't too tall. After a couple of rounds of dodging trees and flower bushes I went back to the shed and got the CA with the L59 Woods. If I had a preference I would use a belly mounted mower. The 3PTH is better for wide open spaces and takes a lot of HP. The 2584 that I have is rated at 48HP, the D17IV does very well with it.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 11:02am
He won't be able to do pastures with a ZTR.  If he gets one he would need the kind that has suspension, or he can kiss his back and kidneys goodbye.  I run a six foot WSoods finish mower behind a D14, and could have gone bigger.  I would sugget a 7 or 8 foot with rear discharge for optimim capability.  If you have a lot of narrow areas you may want to go with a six foot.
Unless you have small trees or brush, you can lift the finish mower and do the pastures.  I have done that and it does not seem to have hurt my woods mower.
I have not found a reason to spend the money on a ZTR and have it sit there only to cut grass, when I can have a tractor and use it for many purposes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 11:06am
Got that covered with the bush hog.
Yes, plenty of open space.
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 11:44am
I used to mow 3 acres with a D17 III D with a 6 ft JD finish mower (barely wide enough), now mow it with an Exmark ZTR 5 ft cut. The Exmark is a little faster cutting but a lot less trimming time. But if the ground is not pretty smooth, I can cut just about as fast with the finish mower and have a lot better ride. Also as my trees grow, i can mow under them better with the ZTR.
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 4:30pm
I bought a kubota diesel z-21 and am amazed how fast they mow. For grass, zero turn is the only way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 5:14pm
I have a Country Clipper ZTR. I was using a 446 Case with a 48" deck that has been repowered with a 20hp Onan. The Clipper will handily out run and mow the Case. I can mow my place in about 1 1/2 hrs where it takes almost 3 on the Case. I keep the Case because it has a Trac Vac on it. The only thing limiting the Clipper is ground terrain. The Clipper is easy to run with it's joystick control. One hand to drive, the other to lift tree branches and refreshments...
Dave H M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H M Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 6:55pm
If it is lawn and not open space here is my take.  We have a zillion trees and the Z is the only way to go.  Also tractors are not allowed on my lawn.
My neighbor can be mowing in the morning, I wil go out and fire up the El Toro and in 2 `1/2 hours park it back in the barn and I can sti get pleasently zoned out in the relax mode and he is trying to finish up in the evening.  I mow a heck of a lot more lawn than he does.
Now I have another question.  Has he considered letting some of the land go to prarie.  I got it all around my lawn and enjoy, if nothing else the call of the quai land the entertainment of the juvenile meadow larks when they emerge to forage in my lawn.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 6:59pm
I have a Snapper built by Country Clipper with the joy stick, had it 12 years. It beats the tractor by 1/2 the time on 3 acres. Right after I got  my wife asked how the heck do you steer it. I showed her the joy stick and how it worked and I have'nt seen the mower  since. and she says" It's mine and I'd better not catch you on it".
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 9:01pm
Go with the ZTR Dixie Chopper. I ran our fairgrounds new Dixie Chopper and it has a 72 inch cut and a 37 horse 4 cylinder CAT diesel. Its a beast and has a rather smooth ride in the 10-15 MPH range.
If fishing is a sport your looking at an athlete
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:31pm
Roundup herbicide. I absolutely loathe mowing lawn. I don't know if any machine has been invented to make it tolerable. I have a CA with a 6ft. woods belly mower, a 1920 Agco-Allis and neither is very handy around all of these trees. I am giving serious consideration to a zero turn myself.  Or roundup.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:44pm
If you decide to go the tractor/finish mower route, be sure to get a mower wide enough to mow out the tractor tire tracks.  I formerly used a WD with a 5 ft Woods 3-point mower. It mowed fine, but was difficult to trim around trees or up next to objects when the tractor wheels were set wider than the mower could cut.  FWIW........O_O
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 10:51pm
There is a round up rate for stunting grass without killing it on the label.
Gerald J.
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 11:29pm
I love my tractors, but man are zero turns fast and fun!
ernie (ECIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ernie (ECIN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:53am
I bought a cheap zero turn about five years ago and hated it. I bought a real one last year with a fabricated deck and real hydrostat drive. It is really the only way to go unless it is wet. The speed alone is worht it, but the finish is great. I bought a 48" Cub Cadet ZTR (needed the narrow width to get thru areas without having to trim) and 23HP Kohler engine. It is worth it's weight in gold many times over. A neighbor has one with the 72" deck and diesel to mow his 7 acres and does it in two hours. Cost wise it is more, but I really feel the time savings and quality of the newer zero turns make up for it. When it is really wet, you do need to be careful or you will tear up grass, otherwise you couldn't get me to give the unit up. I bought it last April with one year free financing and paid it off last month and I have absolutely no complaints, except that I wish it was an AC!
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 12:51pm
If its rough the ZTR will kill your back and kidneys, if you have steep you cannt keep the ZTR from doggin down hill and you sit up high on most ZTRs.  In smooth level you cannt beat em, although you can go to fast.  I prefer my Simplicity Legacy, 60 in cut, 25 hp, power steering, foot controls.  I also have two Dixie Choppers, they are ok, but the dealer was not ok.  I would rate the Choppers as good machines, they are the commerical models.
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 2:00pm
About 12 years ago I bought a Ransomes Jag 4000 (made by Bobcat) with 6ft front deck, 50" snow blower, and cab on it too. It's got a little 31hp diesel for power. I have mowed in a rain storm that would have stopped other mowers. All I saw was a green fog coming out of the discharge shute. I watch all the time for a brother to it for a parts mower. No luck yet. A ztr is best for trimming close to things, but a tractor with a belly or finish mower is best for long mowing runs. Turf tires are a must on most lawns too. Like others on here, I can't see paying 5 to 15 thousand $ for something that wii only mow grass also. But you should do whatever make you happy..........  FredinInd
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 2:15pm
I got rid of my ZT when I moved because I didn't hardly have any thing to mow around and it wouldn't handle the bank out front. I used to use a B Farmall with a woods belly mount but tree limbs were a problem. I could go back to that setup now but I love my brand new Allis Chalmers lawn tracter! Just wish the deck was wider.
It all depends on what he has for a yard. Lots of trees and flowers and not much open space then a ZT is the way to go. Lots of open space get a lawn tractor. Also with a tractor you can wave at the neighbors, hold a cold beverage, and smoke a cigarette!
mojo/Mike
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:37pm
I have THREE Dixon ZTRs... all mechanical drive... a 30", and two 42"... one with stock 14hp Kawi, and one little monster with an 18hp twin-cyl B&S... THEN... I have a 62" Bobcat with 27hp Kohler Command.  I also have a bunch of IH Cub Cadets with typical fabricated and stamped decks from 42-50", and an IH Cub 154 with narrow turf tires.  I have a JD #5 sickle mower and a 5' rotary that I use behind the Allis B and the D17.  I have a 21" self-propelled walk-behind and a Stihl FS-80 brushcutter for fine details.   We live on 5 acres that has a combination of flat open space, as well as buildings, single trees, a grove of catalpa trees, two grain bins, four propane tanks, 9 flowerbeds, a small pond, and all sorts of other stuff lying around.  We're bordered by corn/beanfields, and a gravel road with ditches.
Here's my 'take' on it:
Mowing along the fields, through the bottoms of the ditches:  5' rotary behind the D17.
Mowing the wide-open spaces, between buildings, sides of most of the ditches, around most trees and flowerbeds:  the Bobcat ZTR wins.  It wears 23-10.50-12 Titan ag-treads filled 3/4 full with Propylene Glycol, and the front 'caster' wheels have been filled with tire foam.  To smooth the ride over really hard spots, I converted the front casters to a 'knee-action' suspension, but the ride is very good considering most other ZTRs of this size.  For my wife's safety, I built a full roll cage with lights at shoulder and foot level for 360-degree illumination, there's a steel canopy on top, so low branches don't come in and stab the operator in the eyes, also keeps me dry when it rains... or hails.  There's an FM reciever/MP3 player in the canopy, with a cord going to automatic noise-suppressing headphones (the kind you use for sporting clays, etc... ).  I have a piece of PVC pipe on one side of the cage, inside which is a pole-type pruning saw, and on the other side is a scabbard with a machete, for those instances when a low-hanging branch or sapling needs to be truncated (hee hee)... and there's a fire-extinguisher clipped beneath the seat.
I use the really small Dixons for those times when I have really close-in finish mowing to do around the house, buildings, etc., and along shrubbery, inside the tree groves.
I no longer use the garden tractors for mowing.  Period.
Cut quality-  the Bobcat and the Dixons yield the nicest cut.  The 3-point mower slashes through crud along the fencerows, and the sickle...well, if I had 3-4' high grass on flat surface, I'd use it, but it generally doesn't get used otherwise.
If I were to have JUST ONE MOWER... it would be the Bobcat.  Regardless of any other factor, the big commercial ZTR will cut more ground better, in less time, and with less fuel, than any other machine in my arsenal... and even if it DIDN'T have the high top-speed, or ability to cut AT that speed... if the 3-point hog, or one of my garden-tractors could out run it, the big ZTR would STILL out-mow, because it takes no time to turn it, no planning to maneuver, and no muss-or-fuss to negotiate an obstacle.
Tearing up the lawn... our soil and lawn doesn't suffer... even with ag-tread tires.  IF you insist on doing a planted-foot 'pivot', you'll leave a divot, but proper operation doesn't pivot on one tire.
Ride quality?  The D17 and Allis B have larger tires, so they ride better, but you can't drive 'em over the cistern or septic tank, and they won't maneuver through areas as well, or as fast, or cut as thoroughly as the ZTRs.  As far as wide-open space is concerned, I couldn't run the D17's 5' blade through grass any faster than the Bobcat could cut through, and get any better cut quality.  BOTH mowers would require two passes in order to get it done right, and the Bobcat will do it faster.  The D17's only advantage, is that it's tires, footprint, and ballast gives it the ability to climb out of muddy holes that the ZTR will mire within.
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 5:57am
I guess I would encourage Dad to get what he want so he can experience first hand. It kind of sounds like Dad has his heart set on one. I have a CA with L59 woods . Also have a Jd and woods diesel zero turn both with 60in deck. I havn't used the CA for 2 years. We love zero turn but have lots of trees ect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 6:29am
Here's my take...neighbour(more money than brains) bought a brand new Kubota 3030(?) with 5' belly mower, this thing has Air conditioning and cd player to boot. Cuts his 2 acres in 1/2 hour....NOT fast enough, so he buys an Exmark ZTR unit, 5', does about 18MPH(?) , I know  it's faster than the Kubota as he cuts grass in 18-20 minutes,also pull wheelies.
I'm not impressed. first HUGE cash outlay,esp. the ztr units(there ain't much too them), second, once you're done the grass,there's a lot more time for other 'wifey' chores to be done.
If cutting grass is that much of a pain, hire a kid to do it,cheaper in the long run or do what I did, turn it all over and grow your own veggies.Wife gets free trip to Florida every year from the profits from our 1/2 acre garden, and that's AFTER our freezers are filled.
Just my take.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 6:55am
I thought about this post again last night.  I was mowing with my small tractor, the 5020 with the 5' deck.  As I was rolling along pulling my roller, probably 300 to 400 pounds, I was wondering what that would look like had I had a ZTR?
I also found a definate grass killer, if that is what you want to do.  Mix acetone and trans fluid 50/50 and pour it on the lawn.  I accidently did that last fall and I don't know if that spot will ever grow back!!!  LOL!!!!
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 6:11pm
A commercial grade ZTR is hard to beat for a lawn.  Open field tractor is OK but before I bought mine I talked to several folks that changed from small tractor to ZTR and all agreed they should have done it long before.
Only part that may bother you is the ride is not the best on rough ground.  Partly because you can cut real fast with the new ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 7:01pm
OPGA, Buy some sheep, end of mowing and trimming. LOL I have an Areins 12-42 zero turn. I like it, but it is limited on any side hill. The uphill wheel has to turn slower than the downhill one in order to go straight. I usually mow up and down any slope on an angle, and mow the opposite angle next time. If you get into the commercial Z turns you probably won't have that trouble but you would be putting out several thousand more in cost. A 3 pt finish mower would be handy if you use the tractor for other things during mowing season but won't trim as close as a belly mount. Lots of ideas and input but your property layout and other uses for a tractor will determine your own best answer.  Charlie
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:05pm
I use both to mower my yard. the WD45 and a 7' finish mower and a WD45 with a 80-r or a #7 and a Grass Hopper with a 54" deck. one is good but all three makes the job easier.
Don
Edited by Don(MO) - 14 Apr 2010 at 9:11pm
