AC 416S stuck in second
Frank Dodson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frank Dodson Quote  Post ReplyReply Direct Link To This Post Topic: AC 416S stuck in second
    Posted: 27 Jul 2015 at 4:57pm
I have an AC 416 shuttle that is stuck in 2nd gear. Any suggestions as to the fix? Thanks for any help.Confused
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 8:41pm
Sounds like the shift forks are stuck. What I usually do is remove the pipe plug on top of the transmission so I can access the forks and the shifter stem. You can access them with a bent screwdriver or with a good cotter key puller. Get them unlocked and sliding back and fourth and lubed.
Edited by ACmowerguy - 28 Jul 2015 at 8:42pm
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 10:19pm
Take a peek at this.
Not sure if its the answer, but it doesn't hurt to look.
The mechanic always wins.
This page was generated in 0.645 seconds.
