200 kW Generator Issues
Eladlien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eladlien Quote  Post ReplyReply Direct Link To This Post Topic: 200 kW Generator Issues
    Posted: 20 Jul 2015 at 1:26pm
Good afternoon all.
I have a 200 kW Allis Chalmers generator set that I am trying to troubleshoot, but I can find ZERO information about them online. I am about 90% sure the voltage regulator is out, but I can not find and specs or methods to test he individual parts on it to see if it is even repairable... I can not even find anyone that has ever even worked on one locally.
It will start and run like a champ! No fluctuation in speed at all! But it will not hold voltage. It goes up and down from about 220-480 in a steady wave form. Don't think it is the brushes and rings because of this smooth transition wave...
Any an all help would be greatly appreciated!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 6:32am
Get the manufacturer name off the regulator. Most of those were purchased from a specialized producer, could try to find them or their end result buyer for information. Allis Electrical if they made it was sold off to Siemens.
Does sound like a bad regulator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eladlien Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 10:16am
I can not find any kind of tag on the regulator it self... Only thing I can find on the generator even has a part number and a serial number and that is on the same panel as the controller...
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 1:19pm
You might try looking up "Lima" generators. If it's a true Allis gen set and not an Onan or Kohler, the generator itself was made by "Lima". At the Harvey plant where the Allis gen sets were built, Lima's were all that was used.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 9:10pm
I sold Hobart welders one time and if the brushes got worn you needed to tighten the tension.Just a thought if it has brushe do not know beans about your generator.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2015 at 11:22am
Generators of this size didn't show up on the dealership's floor in very large quantities, weren't sold in big-box stores, and weren't a high-volume 'special order' for farmers.
This was a rather specific market and NOT 'farm-specific', but suffice to say that Allis-Chalmers was much more of an electrical and power transmission manufacturer than agricultural and industrial machinery.
Generators of this category were frequently 'custom' built per a specification, and those specs often identified what the CUSTOMER dictated... and that being said, your Allis generator MAY have an Allis-built prime mover... or it could have something else. The generator and exciter MAY have been an Allis-made unit, or it may be by someone else. The voltage regulator, control relays, and transfer switch MAY have been made by Allis-Chalmers.
You'd be hard-pressed to find an owner's manual for this bugger, BUT, there's a really good chance you could find books on individual components and diagrams for generic or similar applications.
Voltage regulation on machines like this are typically accomplished at low-level, meaning, you have a main alternator which has a field, and that field's intensity determines output voltage... and that field is energized by an exciter, which is a DC generator typically driven off the same shaft. The Exciter, like the alternator, consists of two windings-one spinning and one not... and ONE of those is a field, and it's intensity, like the main alternator, determine's the excitation output. Typically, this point, is where voltage regulation STARTS... controlling a little current into the exciter field, provides control of exciter output to the main field, which controls alternator output.
So the regulator is usually sensing alternator output, and modulating exciter field input... it's a closed loop feedback.
The regulators of these machines are TYPICALLY mechanical in nature, and fascinating, but not very complex. A common type is the REG-Ohm, which your generator JUST MIGHT have, so I'll describe it, and if yours is newer, it may have something different, but same concept applies.
The regulator has two wires coming from the exciter field... and placed in series with this exciter field is a string of resistors. The resistors are placed in such a way that the resistors can by 'bypassed' by a rolling steel bar, and the bar is on a slightly inclined ramp. When at the bottom of the ramp, the bar shorts out ALL the resistors, allowing full field current. At the top of the ramp, is an electromagnet, fed from the main alternator's output. As alternator output rises, more current flows through the electromagnet, pulling the bar UP the ramp, thus, introducing more resistance INTO the exciter field, which lowers alternator field intensity, and lowering voltage output, which reduces the electromagnet's pull on the bar, so the bar falls back down the ramp.
Somewhere, that bar 'finds' a position where there's balance between the incline, and electromagnetic pull... and this is the point where voltage will be maintained.
Many guys who bring old generators back to life have unstable voltage problems, and most can be traced back to one of just a few things... first, is that the mechanical regulator is in some 'non-level' orientation... either the generator is sitting on a trailer on a hillside, or the rubber vibration-isolator 'feet' are all rotted off and the regulator's being rattled around.
Another common issue, is that the contacts that the rolling bar are rolling on, are all corroded, and either impeding the bar, or preventing it from making reliable shorting contact.
Sometimes, the wiring is just lousy and not allowing the regulator's attracting coil to carry current consistently.
Also, it is likely that worn brushes on the alternator or exciter are dirty enough so that there's a consistent output voltage 'signal' for the regulator to 'follow'... so the reg may be 'hunting'.
NEXT... generators in this size range were frequently equipped to run in 'groups', where they're paralleled together to hold down the entire house loads for large buildings, hospitals, etc... and in order to work in pairs, they had to be able to synchronize their alternation speeds AND balance loads by not 'fighting' between voltage regulators. This was accomplished with special setups of the engine's governors AND their voltage regulators. IF yours was set up to work in a group, and you're now running it solo, you've got some learning, and a readjustment/reconfiguration to perform. Not difficult, but best to understand the master/slave operating theory of your machine's components prior to attempting adjustment.
The Smokstak forum has a segment dedicated to generators of many, many varieties, and there's a unique genre of guys who like working on 'serious' generators over 30KW. IF you choose to pursue this big gal, it would be an excellent place to post pictures of the machine, model number ID plates, any connection diagrams, etc., and most likely, any feller who's worked with a similar machine, or any COMPONENT of your system, will chime in, probably Email you whatever docs they'd have for same.
