Differential bearings
chris 21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris 21 Quote  Post ReplyReply Direct Link To This Post Topic: Differential bearings
    Posted: 17 Jul 2015 at 9:23am
I am at a point to were i can replace differential carrier bearings. The problem is the bearings don't look bad and i don't know if i would be able to replace them and get everything back together properly, backlash, bearing preload, etc. Are there any videos out there of this being done? I have read the procdure in the the manual and i have a hard time understanding it. Any thoughts?
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 11:13am
Here you can see how the bearings are adjusted.  The big threaded pieces can be used to tighten or loosen the bearings and can also move the ring gear closer or further away from the pinion.
and the link to a couple more pictures.
http://home.comcast.net/~old_allis/ac-RC-chassis.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris 21 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 11:40am
Thanks for the pics. Are there torque specs. listed for this type of repair? My shop manual doesn't have any listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 11:47am
I don't remember any torque specs on this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 4:38pm
I can't say for 100% on a tractor, but that diff is designed just like a Ford 9" with the threaded carrier bearing adjusters. There isn't a torque spec rather it's measuring the bearing preload rotational torque with a an inch pound torque wrench. I shoot for 15-20 inch pounds on the pinion then add another 10 inch pounds measured from the pinion nut with the carrier installed. With threaded adjusters I would strongly recommend you check tooth contact patch before you call it good. .005-.012 is typical backlash in an automotive axle.
Now here's where it gets a little interesting. You're probably installing the original gears likely with a wear pattern on them. I was talking with Dr Allis on this and he says many times in the past he found that restoring bearing preload and correct center tooth contact patch made more noise than before. He did say that he would typically install them with more backlash than original. Sometimes it helped with noise but not always. Sometimes they can sound like they're grinding away and live a long happy life, other times not.
The point I think he was try to get across was if I mess with my noisy rear gears, it's a lot of work and very possibly I might make the noise worse.
Edited by Brian Jasper co. Ia - 17 Jul 2015 at 4:39pm
This page was generated in 0.123 seconds.
