920 diesel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: 920 diesel
    Posted: 17 Jul 2015 at 7:40am
what's the best way to move it, without it running? thinking I shouldn't pull it since it's hydro won't be running! want to move it to another storage building about 500 ft away.
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 8:11am
If it's hydro there should be a disconnect on top of the rear end under the seat. Small piece of angle iron ya pull up on.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 8:19am
I don't know if the 900 series is like the 700 series, but the 700 series has what DGrader is talkin' bout'. To put the Hydro in free wheel, you push the bracket down (not up) which in turn pushes in the two valves and releases the hydro. Then you can push it around anywhere...
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 9:24am
The way Steve said is how my 916 hydro releases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 11:20am
Steve your right. Got it backwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 7:31pm
No problem Stan the man. Now I know the 900 series works the same way. Is it the same hydro as the 700 series?
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 7:43pm
Dont move it so far without it running or the pump may break. I have seen the results and it's not good. The relief valves are just to move the machine a short distance as across a garage floor( 10-15 ft).
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 9:39pm
thanks...i'll look for that valve thingy!
