WD steering wheel
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD steering wheel
    Posted: 17 Jul 2015 at 6:00am
My Steering wheel needs replacing.
Looks like the PO tried to use a puller to get it off but failed.
I guess punch the pin out and use a saw-zall to cut one side and use a wedge to open it up?
I don't have a torch.
Charlie
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 6:13am
Yes, thats the way I had to do mine.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 7:17am
I tried to use my 2 jaw and then a 3 jaw puller along with a good beating and heat.  Fought it well for a week and then decided I needed a proper bearing puller set.  Took all of 5 min to get it off with the proper tool.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 8:11am
How does a bearing puller apply more force? They look to be near the same tool
Charlie
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 8:21am
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 8:30am
I bought a 250.00 gear puller (a large one) and don't have any trouble pulling anything apart with that thing! LOL! It's a three jaw setup and worth every bit that I paid for it, too!   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 9:15am
Ah, I see. That puts pressure all around.
Thanks!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 9:34am
The Harbor Freight one Don posted about is the one I purchased and used.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2015 at 10:28am
Take the pin out, then remove the pin from the steering wheel side of the universal joint down behind the frame,  Now you can remove the steering wheel with the shaft.  Now clamp a piece of pipe just big enough for the shaft to pass through, firmly, very firmly, in a vise.  Pull the shaft through and slam the wheel against the pipe and it should come off fairly easily.  Don't be a wimp on the first couple of slams.  A pipe vise or one with a pipe or round stock feature works best.
Edited by TedBuiskerN.IL. - 17 Jul 2015 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 9:07am
HOW do you get the pin out without a torch?  I know it is tapered.
This page was generated in 0.158 seconds.
