WD45 Serial Numbers
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Serial Numbers
    Posted: 10 Apr 2010 at 8:53pm
according to tractor data it should be on the left brake housing...no dice....where else can I find the number to see what year mine is?? Only number I've found was 150217 on the back of the rearend housing but I havent found it to cross to a serial....any help would be great....thanks.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 8:57pm
That could be it if it has WD in front of it and it's hand stamped. It would be on the back side of the rearend just below the left brake inspection cover. 1953 if that's it.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 8:57pm
That would make it a 1953
