biodiesel gunk in fuel tank |
Post Reply ![]() |
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2370 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jul 2015 at 5:04pm |
So my MM Vista G1000 aka "Big Mo Nasty" has been sitting for 2 years with bio-diesel in the tank waiting for me to replace a scored piston. I'm currently working on getting it back up and running and need to get the gunk out of the tank. Any suggestions? Its a 52 gallon tank with a fill hole the size off a WD or D17 so there isn't a whole lot of room to work with there.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24507 |
without knowing/seeing the tractor....
could you use one of those 'diesel fuel' rated 12 volt 'transfer' pumps to suck it out into TWO 45 gallon drums ? I might be tempted to siphon it but... a pump sounds a whole lot better and safer ! Jay |
I already pumped all the fuel out but the gunk which is like sticky tar is stuck to the bottom.
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3799 |
I have used a steam cleaner to wash out fuel tanks before. You also could try some E85. It's eats Biodiesel growth. I got a few injection pumps to work again after running E85 through them. Matt
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8284 |
I done this on an XT last winter, put a few gallons of lacquer thinner in it, slosh it around, let set a few days then power wash it out,, be good as new
Auntwayne ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Get a "SMALL" can of carb and choke cleaner, spray a little bit into the tank and let drain. Instant gratification .
Edited by Auntwayne - 13 Jul 2015 at 10:58pm |
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I used E 85 on a Hesston crawler (Fiat) tank, took several batches but finally got it clean. Learned the hard way to only use bio diesel in the summer and then run off road diesel for the last couple tanks. Or drain the tank at the end of the season before it has a chance to gunk up. Good luck!
Allis Express participant |
Think I'll give the E85 and a pressure washer a try. Thanks for the tips
Post Reply ![]() |
