WD Hydraulic problem
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulic problem
    Posted: 02 Jul 2015 at 11:59pm
I could use some thoughts from anyone. When I hook up equipment to my auxiliary connector on the rear, there is pressure on the hose but no lifting. Could this just be the wrong ram, on the mower, for the 45 system? Have tried different settings on the pump but no change. Any thoughts?
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 7:10am
Are the cylinders on the equipment you are hooking to set up for single action or double action? Are there 1 or 2 hoses on the cylinder? The WD was designed to run single acting cylinders (one hose). If the cylinder has 2 hoses on it, remove the hose that is not being used and put a cylinder exhaust port in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 7:14am
Coupler  bad if it has pressure on hose before coupler. If pressure after couppler, the hose could be plugged.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 7:48am
Your tractors lift arms should go up and down as you raise and lower the hydraulic lever. If they work, you must have bad or mis-matched coupler parts. If the lift arms don't do anything, you have hydraulic pump problems.
This page was generated in 0.234 seconds.
