H3 engine?
wildbill26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Topic: H3 engine?
    Posted: 01 Jul 2015 at 5:30pm
What engine would an h3 have? It is gas but what size?
1950 wd wide front w loader
1940 b, 1939 m crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 5:48pm
I believe a 149 ci, same as a d-15, series 1
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 5:29am
I think it could also be a 160ci if its a late model H3.
Edited by chevytaHOE5674 - 02 Jul 2015 at 5:31am
jughead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:43am
how would one tell the model? serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:54am
Thanks guys, I didn't know if it was a 149/ 160 or a 226
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 5:44pm
What shape hole is in the sheet metal where the muffler goes through?
TOM H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 11:12am
The Allis Chalmers H3 gas was introduced in the fall of 1960 with an AC 149 CI motor. In 1963 at serial # 6001 it received the 160 CI AC motor. I believe the larger 160 CI coincided with the change to a dry air cleaner and an oval muffler at the same time.
Allis-Chalmers 1927 E,1928 U,1944 WC,H3,D10,D12,D14,D15,D17,D21,TT-10 Terra Tiger, 1964
AC Golf Cart, Allis Chalmers Fridges,100's of AC Literature and Ops.and Parts manuals
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 6:47pm
Even the first H-3 had an oval muffler. The oval is 7" the same as the D-10/12 Series III.
I have serial 1105 (1960) I don't think the 160 cu.in. later H-3 had a dry air cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 11:55am
you answered my question mine is 10k plus thanks to all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 7:13pm
I stand corrected. Sorry. I shot from the hip. Calvin is correct in that ALL H3's had the oval muffler and also the dry air cleaner was added later after the engine was upgraded to the 160. The book by Norm Swinford states that the dry air cleaner was added when the engine was changed to 160 CI but the actual parts book shows a serial # change later in 1965 when the engine speeds were increased to 1600 RPM. I have a 1966 H3 #8961 and it does have both dry air cleaner and oval muffler although the muffler on there now is round due to prior owner could only find one like that. There is a place on side of block (hard to find)that gives serial # of engine and mine also has 160 before the serial number. It has the 6 way AC blade on it. Runs great but smokes a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 7:37pm
Here is a picture of my H3 after I built a dike with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 1:04pm
would delete post but too dumb i guess
Edited by jughead - 13 Jul 2015 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 1:07pm
one more question please the  engine number on my h3is 2160 R the serial number on the unit is 10k plus would like the year model if possible thanks  sorry about the blank post pushed the wrong button
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 9:23am
any special reason no one has replied to my post. didnt think i was hi-jacking.
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 11:38am
Norm's book says the last serial number for an h3 was 9949. Made in 1967.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 6:59am
oops i was told the serial number is located on the part that the dozer blade is fastened to in front of the radiator. now i am confused. dont know what is going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 7:22am
The serial number is located on the left side, on the torque tube or clutch housing just behind where the engine bolts in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 7:52am
http://people.clemson.edu/%7Ewsmth/images/SND15.jpg
Look in the area of the white tape for the tractor number and just ahead of that, on the block, is the engine number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 8:03am
will do. going back out there today and make sure this old man didnt write down numbers wrong. getting to where i have to triple check everything i do then have a 50 percent chance of being wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote jughead Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 8:54am
my previously posted numbers are correct. so what ever it is i got it and i am enjoying using it. thanks to all for putting up with me and my lack of knowledge but one doesnt get to old to learn.
This page was generated in 0.258 seconds.
