210 220 7000 series wheel push bolt thread size
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Topic: 210 220 7000 series wheel push bolt thread size
    Posted: 01 Jul 2015 at 6:54am
Hey guys Does anyone know what the threads are on the pusher bolts for the latest style cast wheel wedges? As on a 210 220 7010 on up through the 8550? I tried a 7/8 Standard thread and Fine and it is something different. Any thoughts? Thank you!
Andy
Andrew Gubbels
Gubbels Restoration
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:03am
they are 7/8" but an odd thread, I think 12 is the pitch.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:07am
Seems to me it was posted that some Case/IH uses same 7/8-12? Might try there if they are closer than AGCO
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:55am
I just looked at my tap for this, and it is indeed 7/8"-12.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 9:14am
It is special, I bought a tap from Enco years ago for this, I will check to see what it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 9:57am
Great! Thanks for the input guys! Always appreciate everyone's help!
Andy
Andrew Gubbels
Gubbels Restoration
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 2:57pm
I found that there is a thread that is called 'Industrial thread' that is neither coarse or fine. Found it on the adjusters on roller mills that I sell.  More heavy duty but not well known.  Could that be it?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 3:47pm
How many do you want?
