Propane WC
Freewheelin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Topic: Propane WC
    Posted: 30 Jun 2015 at 10:23am
http://madison.craigslist.org/grd/5099855721.html
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 10:55am
looks like a wd45 to me
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 11:04am
   How do you guys get the posted links to open,,,???
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 1:01pm
I did it the hard way went to Craigslist went to wisconsin then Madison and then I searched allis chalmers there's gotta be a better way right ?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 1:19pm
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 4:11pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 4:34pm
Definately a WD or WD45. Aftermarket, right?  I thought the OEM propane ones had the tank out front.  Whats up with the cap on the air cleaner?
AaronSEIA
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 4:46pm
Benny, something about your link results in a 404 error.
try this
is that propane tank from a D series ?
it has some kind of hood over the gauges/filler
Edited by Gatz in NE - 30 Jun 2015 at 4:49pm
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 5:09pm
Joe, how I do it is, put the pointer at one end of the address, left click on it and hold it down till you get to the other end. Mine turns all blue, then put the pointer in the blue and right click. It will ask you to search it w/ what ever search engine you have installed. Click on it, and you'll find it. I hope this was what you wanted. Tim
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 5:10pm
I thought the tank was out front on the WD and WD45.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 6:20pm
Tank was out front on factory propane models, this is a field-installed dealer option tractor.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 9:45pm
I think the air cleaner cap is a dry paper filter added, my brother got his fil D17 with a similar lokking filter, had trouble for a few years getting it to run right, tried several things them dicovered the paper filter that looked like it had never been changed, threw it away and problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 9:53pm
HIGHLIGHT the posted link, then right click on it and click open in a new tab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 9:56pm
In the one pic of the distributor, you can see the block is cast all the way down the right side. Gotta be a 226 block.
