Error Code E27 on a '96 Agco Allis model #9675
Alex H. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex H. Quote  Post ReplyReply Direct Link To This Post Topic: Error Code E27 on a '96 Agco Allis model #9675
    Posted: 27 Jun 2015 at 8:02pm
Today while running the grain cart for wheat harvest, a sensor failure occurred while dumping grain into the semi. The sensor failure light popped up under the gear shift indicator and the error code was E27.
Tractor Details:
diesel fuel
18-speed transmission
model year 1996
model #9675
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 9:30pm
Welcome to the forum. Error code 27--open coil at solenoid MC2. MC2 coil is the bottom one of the front row of coils on the right hand side of the tractor. There should be a large plastic shield covering the coils and valve body under the right front of the cab. They are by the transmission filter also. A good ohm meter would be helpful to test it against a new one or a good used one. There could also be a break in the harness or a poor connection at the left front of the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex H. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 10:13pm
thanks for your help.
