What model Hay Rake
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: What model Hay Rake
    Posted: 08 Apr 2010 at 10:35pm
Can someone tell me what model this rake is, and what it might be worth.
Brian
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 4:29am
What rake???
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 5:31am
Built by the Invisible Farm Equipment Company of Timbuktu. Can't tell the model from here. Worth quite a bit if you can get your hands on it.
Wink
I am a Russian Bot
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 7:33am
Never needs tires, grease or repair parts! Talk about no maintenance!
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 7:41am
Now where did I park it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 2:23pm
I deserved that one, must be the air in Hawaii. Now I cant resize the picture to fit. It is a pto rake, if you are standing in front of it there are 2 wheels to the left and that swivel and two at the back, on the left side that are stationary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 2:25pm
Sorry, the two wheels at the back are on the right if you are standing at the front looking back at the rake.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 5:41pm
Brian is it like this one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 11:24pm
Don; It looks just like that one, except that it has dual wheels front and back.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 1:16am
The rake pictured is the latest stealth technology.
The rake described sounds like a #7
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 3:30pm
Also, the two wheels front and back are an option that allows the rake to cover rough fields better.  We used some of them with the two wheels in MD on really rough ground
Good Luck!
Bill Long
Fern(Mi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fern(Mi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 8:54pm
As I was into making my second round, Murphy’s law intervened, something had gone wrong with my favorite AC hay-rake. It had either slipped a key, lost a dowel pin, broke a shaft, or worse.  Now I’m desperately a need a shop manual, parts pictures and lists for what I think might be a Model #7 PTO driven Allis Chalmers hay-rake. Likely manufacture late forty’s into the mid fifty’s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fern(Mi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 8:56pm
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 9:52pm
If it is like the one pictured, it would not be a #7.  AC Pto Rake.  #7 had both wheels behind the frame having an over the top frames leading to the 77/78 concept.  Gear box did not have two speed and the PTO had to be changed from Rake input shaft to the tedding input shaft....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fern(Mi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2010 at 6:59am
Any guess as to this machine's model number still remains. It has a single input gear box run off tthe PTO. It has a two speed hay raking and one reverse teding speed with a neutral single shifter gear box.
An absolutely fantastic machine with its gentle nature is (was) is (has) such a gentle way of handling alfalfa.
A 4-bar Case, an 5-bar IH, and a NH inverter (2nd best) don't hold a candle to this mystery model hay rake.
It is the combined total of two simliar machines. An early model grown over and brought out of a windrow. The 2nd later model was passed on to me rather than junked by its formor owned with a broken gear box. This the later one that was in better condition. I added the second wheel to the right hand end from the earlier model. Set up with four wheels it has been very very good at avoiding bottoming out.
Fernan
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2010 at 9:38am
Do the number 7's create corner clumps like the ground drive side delivery rakes did?(Two big steel wheels in front/crazy wheels in back)   Just curious?
Not that I would buy one as I am happy with my AC 77 rollabar style rake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fern(Mi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 8:24am
Afraid so.
and all four wheels are the same size rubber tired.
Fernan
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:30am
Your rake is described in Norm Swinford's book on Allis Farm Equipment. It is a side delivery rake produced from 1947 to the mid fifties.  There doesn't appear to be a model number assigned to this rake.   The #7 rake came out in 1957 and was an improved version of the earlier one.
