Main thrust brg 6080????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Main thrust brg 6080????
    Posted: 23 Jun 2015 at 1:10pm
When replacing rods and main bearings on 84 6080 with original bearings.
Edited by Mikez - 23 Jun 2015 at 1:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 1:14pm
When replacing rods and main bearings on 84 6080 with original bearings. The center thrust bearing supersedes to the newer heavier style bearing which doesn't fit in block. I know you guys are replacing them though. Mack had told me you take file to block to get bearing to fit.
Was there a service bulletin then to explain this procedure, if so does anybody have a copy.
Thanks
Opps sorry for the messed up post
Edited by Mikez - 23 Jun 2015 at 1:20pm
