7010 Air Conditioner |
Post Reply ![]() |
Mark(MO) ![]() Bronze Level ![]() ![]() Joined: 11 Sep 2009 Location: NE Missouri Points: 79 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jun 2015 at 10:22am |
Guys,
I would like to fix my AC on the 7010. It hasn't worked for years. I tried to put some 134a in it and it wouldn't hold any. I'm guessing some pretty big leaks. I was thinking about just replacing the entire AC system rather than try to track down a lot of little leaks. Is there a place that sells a kit with all the parts I would need...compressor, hoses, drier, fittings, condenser? Is this the wrong approach? I want it to work like new without worrying about it during the summer months. I was thinking I could do the work and then have a pro charge the system for me when I am done. Tell me if this is too big a job or the wrong decision/ Thanks in advance for your help! BTW....just bought an 8010 this spring and I love it!!! Will try to get some pictures posted later.
rw ![]() Silver Level ![]() Joined: 28 Oct 2009 Location: United States Points: 384 |
Yep that is the way to go. A whole new system will really make it work.rw
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7518 |
You are going to be replacing a lot of parts that don't need replacing that way. Flushing money down the toilet. Chances are there is only one leak in the system. I am willing to bet it is in the evaporator - my 6080 leaks there. Have a pressure test done on it and determine where the leak is. Fix the leak and convert the system to R134a and you are set. An HVAC technician could do that for you.
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
i'm replacing all the hoses , compressor, everything on my 7010, most of the hoses are brittle. I got all the hoses from A&I, for $500. the new compressor came off my Cadilac as it was new just before I quit driving the car. (same compressor) replacing the dryer too. it worked for 34 years...just started blowing hoses! with everything new it's gonna cost me bouts $650.00. and well worth it! it should be done this week...just in time for tree pulling!
oh...the part numbers for the hoses through A&I are the same numbers as AGCO's. i'll look and see if I still have all the numbers
aras ![]() Orange Level ![]() Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
ap air also sells everything you will need too
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
If you don';tr want to convert to 134a, There is/was a product called freeze 12 that has worked for me.
ivan ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Michigan Points: 319 |
We stock everything for your allis tractors and gleaner combines
JET8070 ![]() Silver Level ![]() ![]() Joined: 06 May 2015 Location: PA Points: 60 |
I've worked on a lot of 8000 series A/C units and quite a few 7000 series units. Some that I got working hadn't worked in over a decade. I will say that I never had to replace the whole system. Not even close. Three most common leaks on these tractors: 1 compressor shaft seal or other compressor seals.2 high pressure hose out of compressor to condenser.3 leaking condenser. Everything else leak wise is a freak occurance. When inspecting lines, leaks sometimes occur where the lines have been coated in hydraulic or engine oil like where the lines start under the cab near the fire wall. In a few odd instances something has occurred that held moisture against steel line and rusted it out. The expansion valve is a good thing to replace if it has been open for a while same with the drier. The high pressure line on 7000 series is prone to be rubbed through on the edge of the hood. The crimp on the high pressure line just out of the compressor is prone to failure. The condensers tend to rot and/or rub through where the bolts with the offset washers go. 7000 series compressors are easier to test due to the service fitting on back of the compressor. Only tractor I ever wanted to replace all the hoses on was a 7000 series with severe contamination from being wide open for several years and it wouldn't flush. Never replaced an evaporator but I had to get some repaired. I know a/c repair seems foreign to many but would you change injection pump,injectors and injection lines because the water in the bottom of your fuel filter rotted out the case from never being changed.
Edited by JET8070 - 23 Jun 2015 at 8:04am |
Well said! |
I do appreciate all of the advice. Think I'll get a professional to find the leak and see how bad it is. I also need to replace the A/C switch in the cab. Last time it was replaced they put a one speed in instead of a 3 speed switch. I will use my 7010 a lot more if the A/C is working!!
Thanks again!
kurtleimkuehler ![]() Bronze Level ![]() ![]() Joined: 07 Apr 2015 Location: missouri Points: 45 |
7000 series compressors are easier to test due to the service fitting on back of the compressor. I cant tell what this is, i am trying to figure out where the leak is in my 7010 suspect the compresser. How do u test the compresser with this fitting?
fourthgeneration ![]() Bronze Level ![]() Joined: 03 Jan 2017 Location: ohio Points: 170 |
I just did the same thing on our 7020. AP air has everything. I would get their Sanden style compressor kit. The binary switch in the kit eliminates the thermal circuit. I replaced the entire system so that I there was no risk of debris being left behind. The r134a adjusted charge is 3.2- 3.45 lbs for the 7020. I got the insulation for the evaporator outlet at Napa. I vaccumed it down over night. Then pressure checked at 200lbs with nitrogen then vaccumed it down and charged it. I also installed a new heater blend valve in the cab and ball valves on the engine to shut off the coolant in the summer.
Edited by fourthgeneration - 24 May 2018 at 5:01pm |
Post Reply ![]() |
