2900 block question |
Post Reply ![]() |
Josh(NE) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Nebraska Points: 514 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jun 2015 at 10:13am |
Stopped at local mechanics shop and he is doing an OH on a 190XT. He pointed out that on this 2900 block there is no oil hole for the rear cam bearing to line up with. Are they all that way or this block a fluke?
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22062 |
That is the way they are. Tell him to not even try to figure out how it works.
So is it normal to have that bearing fail long before the other cam bearings. This thing had plenty of hours on it, but that bearing looked horrible.
Allis Express
No. The front usually looks the worst.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
I was once told they are oiled by magic lol! But I bet what doc said is true if you look at the old bearings. Also, put the new ones in the freezer until right before you install them. Makes it way easier to press them in.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
once overhauled a 2900 out of a cat scan gen power unit. 12000 hours. The cam lobes were almost flat, lifters were cupped unreal, cam brgs were almost perfect - except front was showing bronze, as stated, magic,,, don't screw with perfection....
cranky ![]() Orange Level ![]() Joined: 08 Jan 2012 Location: easton md Points: 205 |
cam bearings rely on oil draining back from rockers to lube bearing journals.it is not pressure fed lube
Post Reply ![]() |
