410 Shuttle
A-Cvtx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Topic: 410 Shuttle
    Posted: 21 Jun 2015 at 8:03pm
Yesterday while pushing some dirt and gravel, my 410 shuttle would stop moving when it got a load on the blade. Not a large load, what I would call a fair load. Any suggestions as to adjustments? What to start? What to check? Thanks!!
Insanity is relative. All of my relatives are crazy!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 5:02am
Isn't a 'Shuttle' belt drive with a geared transmission?
So a stop in motion would mean a belt is slipping ?
Or do you mean 'Hydrostatic' drive ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 10:52am
That's the belt drive. Its 4 speed with F/R shuttle. I didn't have the usual symptoms. Smell of hot belts or squealing. Probably just need to check my tension. Huh?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 3:27pm
Belt tension and belts could be wore out! We have put heavier spring on for heavy loads as pulling. If it slips in first it needs some work.
DaveBsACs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveBsACs Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 8:44pm
Sure sounds like belt slipping, I have found a new set of belts will cure that, just be aware that they can be grabby untill they have some wear on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 6:59pm
I checked the belts. They look ok, just a little loose. Gonna replace spring with a heavier spring, as per farmtoybuilder, and go from there.
This page was generated in 0.172 seconds.
