Gear Ratio difference between a rc and wc
autobody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Topic: Gear Ratio difference between a rc and wc
    Posted: 20 Jun 2015 at 9:03pm
What is the gear ratio difference between a rc and a wc ring and pinion
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 9:19pm
WC 7-32 rc 5-33 4.4 6.6 I think but could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 9:37pm
How much slower would a wc be with rc ring and pinionz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 10:30pm
Not sure. I'm sure some one on here could tell you. I've heard 10 to 25 percent but not sure what it really is. Just put a set of high crop gears in mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2015 at 7:25am
7 x 32 is 4.6 to 1 ratio..............5 x 33 is 6.6 to 1 ratio(if those are the correct tooth counts). This is a 30% speed change (not 10 or 15 or 25%).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 12:07am
Do you know how much slower the speed patrol gears are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 6:14am
I assume the Patrol gears are the same as hi-crop at 6.6 to 1 with smaller diameter rear tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 12:33pm
So we should be able to run 6 mph in 2nd gear on a wc with 16.9-38 tires with the rc gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 12:55pm
How many rpms are u spinning? with that tall of a tire you should be able to run 6mph in first with the WC gears. I've hit 6mph in 1st with 15.5-38s. Also I believe it takes some machining to get the rc ring and pinion to work. I was told they were a bearing short and it was fine for the little rc motor but would hold in a Wc for pulling which is y I went with the high crop ring and pinion.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 1:36pm
Isn't the wC high crop gearset ratio the same as RC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 1:38pm
Yes. Its the same gear ratio but its stronger then the rc ring and pinion because the rc ran a smaller motor then the wc.
Edited by Zaddison - 22 Jun 2015 at 1:45pm
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:51am
if you put rc ring and pinion in take ring gear off rc carrier and put on wc carrier has 4 spider gears instead of two.
This page was generated in 0.091 seconds.
