720 Ignition switch
Brett IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett IL Quote  Post ReplyReply Direct Link To This Post Topic: 720 Ignition switch
    Posted: 08 Apr 2010 at 5:49pm
Was wandering if anyone knew where i could get an ignition switch for our 720 lawnmower. I work at a lawnmower repair shop and nun of the parts catalogs had a switch that matched the poles on the one we have.
Jerry Carter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry Carter Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 6:15pm
I bought one that wold work at my local NAPA store. The only problem is the key is horizontal instead of vertical when in the off position.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 6:22pm
Is it "Indak" style key? if so, I have 1 NOS Simp. #122201 4 pole, labeled D,B,S,C. Other is 5 pole labeled S,M,L,B,G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 7:58pm
I have approx. 24 different types of Ignition switches. May be able to help you out. Drop a line with a pic if interested.......
Steve@B&B
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 11:52pm
Any simplicity dealer can get you the proper switch. The big difference in most other indak switches is the OEM will turn on the oil/hot lights when in the start mode for testing of the circuts.
