G electrical
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: G electrical
    Posted: 08 Apr 2010 at 2:27pm
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 3:35pm
does sound like coil is getting hot, also are you running a 12 or 6 volt bat.? Should be 6 with positive ground. I would replace the coil and check your points for burning and make sure they are set to the correct gap, cant remeber what it is though. Good luck and let us know if you need more info.
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 7:04pm
Is this 6 volt positive ground like original?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 8:11am
Just installed new switches, cut out, all new wiring, generator and starter from tony. Farm and fleet points and condenser, plug wires. 6 volt battery positive ground. Thank you.
