Building D17
DavidBeach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Topic: Building D17
    Posted: 15 Jun 2015 at 10:13am
I have a D17 that am wanting to build up. I had been using it for farming as my main work horse. Have another tractor now that does what I need it to do on the farm. Am wanting to build the D17 to get the most power. When growing up we pulled a cpl of AC and Farmalls. Any help would be appreciated thank you. Oh I know some of you wont want to put stuff on an open forum, so if you want you can email me... lol
david_beach@ymail.com
58 D17
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 11:09am
I guess a stated goal would help.
What class are you aiming to go for?
Charlie
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 11:29am
Gas / Diesel ?
EAT BEEF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 11:31am
Will be gas...
58 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 11:47am
Am wanting to pull in the 4500 up to 6500. Around here they have a 30% over stock on rpms. Am wanting to pull in open gear.
58 D17
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 12:01pm
Are you just wanting to work with what you've got, or build a new motor? You could just start with a bigger carburetor and 170 governor spring. Also a high performance coil and a Petronius system will gain you a couple horse power.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 12:36pm
4500 up to 6500??? So, what will your competition be?? Right off the bat at 4500 pounds you will be potentially be competing with 550 cube Oliver's and M- Farmall's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 2:14pm
Right now engine is out and apart. As far as the Olivers am not to worried about them unless they have come a long way . Am wanting to mainly be competitive. And know in the 5000 and up will be against the 460s
58 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 2:54pm
For example, in the 4500 class, what gear are the 460's running and what size rear tires???
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 3:21pm
I don't want to discourage you because it is your tractor and everybody should have fun how they want, but an allis open speed that heavy will just be hard. Dad and I have a 451ci Farmall M that we occassionally run open speed with, and we are still back of the pack at 160hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 6:25pm
Which this was 25 and 30 yrs go, we were pulling a d17 in the 5500 and was able to get the m and 460s because to much power and not enough weight and still see it here at times. the 460 we had we pulled in the 6500 upto 9500. which in the 9500 we were pulling against 966 and up and again was the weight power ratio. am not looking to get rich just a hobby
58 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 7:23pm
What size rear tires are you planning on using????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 7:26pm
Well i'm talking about our open club has no rpm limit 2. Lol we are swinging a 7.5 inch crank, so we can only turn about 2000rpm. The guys beating us are cranking 4500 to 5500 easy still with 400+ cubes. So don't worry what i'm talking about if your club is limited on rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 8:42pm
most of the 460s are running the 301 out of 806s. Around here they have a 30% over stock rpm, which with a 17 is about 2600. They have the antique classic 4mph open gear 8 and open gear 12. I was looking at the open gear 8 or 12. The 460 we had growing up had the 301, the engine was built and blue printed, we started out at 2000 out of the hole and taking it to 4000. The guy that dad got the tractor from said no, come out of the hole at 3000 and take it to 6500. She would stand up drop down and after that we never took worse than third. The only problem that we had with the 460 was burning a hole in the head gasket between 1 and 2.
58 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 9:23pm
i am planning on goin with 34 16.9 or 18.4 on tires
58 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 9:50pm
I'm sorry. I'm too stupid to figure this out.......4 MPH Open Gear?? So, where I come from that means any gear, you just can't go over 4 MPH. What are the 8 and 12 numbers???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBeach Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 10:11pm
8mph and 12 mph sorry bout that
58 D17
Bled Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 10:25am
I to am wanting to build a1960 17 for our club . class is 7000lb no turbo no rpm limit and no mpr limit wanting to run 18.4 30s . going agenst 460s 400s Ms and any help would also be helpful and you can email me at RMduvall3@yahoo.com thanks
CA, D14, D17, D17VI, 180, 185, IH 140 and one damn deere
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 12:38pm
i have a 17 thats built up and i kno its hard to run with M's and anything 6 cylinder  you need to use a 180 or straight 190.
 Shawn
This page was generated in 0.081 seconds.
