Injector options:
DBRP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DBRP Quote  Post ReplyReply Direct Link To This Post Topic: Injector options:
    Posted: 15 Jun 2015 at 9:15am
 I am currently running 4X.024 old stlye injectors with .093 lines. It has 13mm a-pump, a 2.8x3.0 turbo running 3500 rpms. This is a 500cube 426 and it runs very well now, I just want to know if there is somthing better in injector options. Any ideas are appreciated.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 12:58pm
Dual or triple feed 5 hole Bosch injectors. Fair Valley Performance in Sauk City Wisconsin. Talk to dennis and he can set ya up. 608-643-0200
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 1:45pm
If you are over 500 cc's you will see gains with the dual fed Bosch injectors. The farther you are over 500 CC's the more gain you will see. If money is no object I would contact Columbus Diesel for a set of there triple feed billet bodies and billet tips. A friend of mine put those in a superfarm international and gained 50 HP and about 90 ft lbs. over the stock bodied dual feeds he had previously. Dyno numbers - no other changes - took old injectors out and installed new billets - plus 50.
With that said, as long as the fuel passage through the Allis injectors are .093" or more they are a good performing injector at 500 - 600 cc's or less as long as the tips are made correctly.
DBRP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DBRP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:07am
Running about 730cc of fuel and 1425cc (1.5qt) of water per run. Thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:18am
5x.020-5x.022 Bosch injectors would be a good setup I would think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:49pm
I agree. 5 X 022.
