need expert help fast
boergoatfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boergoatfarmer Quote  Post ReplyReply Direct Link To This Post Topic: need expert help fast
    Posted: 08 Apr 2010 at 7:30am
I am thinking of going to a sale saturday that has a advertised minni moline 2 row 3pt planter.  The planter has been inside but boxes are full of trash.  my main question is is it actually a minnie moiline or a jd the reason ask is I went to see the planter yesterday and didnt see anyhting that says minnie all the boxes say are moline and some other words couldnt really make out. Color of all the boxes was gray or galvinized also is there easy way to check if everything is loose cause bottom of boxes seemed little rusty
Raising tunis sheep and oberhasli dairy goats and driving my allis chalmers tractors... Life is great
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 7:37am
Not much to go on here.  But, I can say for sure that Minneapolis-Moline did in fact make (or market) their own planters, because I used to have one....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 6:12pm
I'm no expert on other planters other then my AC two row planter, but if it is driven from the wheels with sprockets and a chain, I would tip it up on end, and then turn the wheels and see if things move or not.  If it does, then you have a good chance that most of it is ok.  If it's tight, you got alot more work to do.  Most of those planters don't weigh all that much and a good sized guy with a strong back should be able to pick it up.  I can do that with my planter as I stood it on end to save some room in my barn.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 9:16pm
If the boxes say MOLINE, then it is a JD. Bob
This page was generated in 0.079 seconds.
