Posi or diff lock
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Topic: Posi or diff lock
    Posted: 11 Jun 2015 at 9:54am
Gentlemen,
Does anyone have any ideas on a diff lock or posi trac system for an Allis CA pulling tractor? Having issues with one wheel spinning and the other doing nothing making for short pulls which is aggravating to say the least. Any input appreciated.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 12:40pm
Let's make sure both rear tires weigh the same (fluid, 1/2 fluid, etc) and are matched brands and lug wear sharpness, and tire pressures are EXACTLY equal to begin with. If you actually had a diff lock, sounds to me like you would have driven it out-of-bounds, because one tire isn't biting as good as the other. Diff locks don't belong on a Pulling tractor.
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 12:40pm
No ideas but I would think if u locked them to tight u would have a hard time turning and or keeping it straight if one tire hits a soft spot . Can you run the brakes a little or maybe move some weights to the side that's spining.
Edited by Zaddison - 11 Jun 2015 at 12:43pm
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 5:35pm
Is it the same side that spins out all the time
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 8:07pm
If anyone finds out you've locked the diff, don't expect to be able to pull with them anymore. Highly frowned upon around here!!
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 2:32am
Why does a diff lock not belong on a pulling tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 7:52am
Because you cant steer with both wheels pulling at the same speed if one wheel slips your turning that way and you cant use the break to to steer back when on hard ground it goes staignt a head count
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 11:59pm
wait i screwed up here. yes i agree a diff lock wont work on a pulling tractor. however a posi trac/limited slip works just fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 1:08pm
Been a while since I watched tractor pulls but back in the day I don't remember any issues with open diffs causing one wheel spin outs.You got some other problem.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 6:55am
A post several years back concerning the same issue is resolved by someone by adding or removing differential carrier shims to limit one wheel spin. I would guess adding shims would equally to both sides may be the way to go and not lock up the rear end.
