Steering u-joint part number
RoyR (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoyR (MI) Quote  Post ReplyReply Direct Link To This Post Topic: Steering u-joint part number
    Posted: 07 Apr 2010 at 5:57pm
Does anyone have the NAPA number for the u-joint used to replace the steering joint on a WD?  I bought a couple a few years ago, but didn't write the number down.  The kid at the parts counter just gives that blank stare if it's not in his computer.
Roy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 6:20pm
This won't help you but, I found one  off of an All Crop combine I scrapped out many years ago. It is the same u-joint except it has keyways cut in both ends and a tapped hole for a setscrew instead of the through hole for the roll pin. I had purchased a new replacement but thought it looked to big around. It wasn't shaped like the original. I still have that one around somewhere.
Edited by CTuckerNWIL - 07 Apr 2010 at 6:21pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 7:48pm
I have one in stock, #861. I don't need this one, $10 shipped to your door if you can wait. I also have good used joints if that helps. I think they are same for WD, WD-45, D series, that's what I wrote on box.
MLGoodwin82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MLGoodwin82 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 7:59pm
If he doesn't want it, let me know!  I have a WC.  I think they're all the same.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 8:17pm
  there are 3 different ones used  we have all in stock   good   better   best
   1-800-254-3116
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 10:50pm
Can just the "yoke" be purchased or must a person buy the entire assembly?
This page was generated in 0.069 seconds.
