Agco 2027 |
KarterC
Topic: Agco 2027Posted: 04 Jun 2015 at 11:05am |
I found an agco 2027 with 164 hours in very good condition with a bagger and single stage snowblower. they are asking 5500 for it. is it a good deal. did these machines have many problems.
talntedmrgreen
Joined: 25 Jun 2013 Location: Caledonia, MI Points: 477 |
Posted: 04 Jun 2015 at 12:40pm |
The hours are super low...depending on the age of the tractor. No real changes from 2005 to 2015. The blower will perform very well for you. Is the bagger a triple bag, or is it the wide body cart type? Both are awesome and utilize the Simplicity turbo vac, which runs off the outer deck spindle. It is the very best vac I have used. These machines are great...a perfect blend of sub-sub compact tractor ability, and mowing agility of a garden/lawn tractor that cuts with the best of Simplicity's legendary mowers. If the tractor had only a deck, and was one of the 2x4 gassers, I would think $5500 is higher end. Since you have the vac, bagger and blower, I think $5500 sounds pretty darn good. I would think a cheaper machine could be found, but probably a tough find, and probably not so low hour....or with the all-season package you have found. If you find that you have the diesel, it's a no brainer. They cost significantly more and have a fantastic, long lasting and fuel efficient reputation. If it has 3pt hitch and/or rear pto, those are also significant options. 4x4 was available as well. There are many attachments available for these, and with patience, you can find a good deal on: Snow cabs (vinyl or glass) hydro angle dozer broom loader 3 point hitch/540 PTO and all the common subcompact tractor attachments that are compatible 2 stage blower |
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
KarterC
Posted: 04 Jun 2015 at 2:28pm |
here is a picture of it it has a 48 inch deck with triple bagger I believe it has a kohler in it. it is 2wd
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 05 Jun 2015 at 11:30pm |
thats a nice looking little tractor dosnt look like they have changed the snow blower much in the last 50 years but theres no sense in changing somthing that works so well
