8050 steering cyl disassembly
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Topic: 8050 steering cyl disassembly
    Posted: 06 Apr 2010 at 9:38pm
I have an 8050 fwa and the steering cylinder needs repacked. i have repacked other cylinders with good results but i cant seem to get this one apart. most others unscrew but this one has a snap ring. i removed it but cant see what is holding it from coming apart. can someone shed some light on my situation? thanks to all in advance for any help....JB
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 10:10pm
You have removed an external snap ring with eyes-correct. Now gently tap the gland into the barrel until you see an internal ring in the barrel. Use a knife blade or small screw driver to peel it out ,then you can remove the rod and piston assembly.
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 10:11pm
  I think if you have removed the snap ring it should be ready to come apart.  I usually use the wand with compressed air held against the fitting that extends the cylinder.  Be careful that it wiil come apart in a safe area preferably something a little soft to hit.  Service manual is at the farm so not 100% sure on the just one snap ring though?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 10:13pm
  Lynn is correct on the internal ring
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 10:15pm
Thanks alot.That makes sense. I figured it would be something simple that i was missing. Thanks again ...JB
