B112 mower deck
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Topic: B112 mower deck
    Posted: 29 May 2015 at 9:05am
Will a later deck from the 900 series or perhaps from a homesteader fit this tractor?
Were the originals painted the same yellow as the tractor?
The tractor has never been used for mowing-rototilling only.It seems to have the drive components on the tractor side though.
Any help would be greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 2:01pm
Any of the B series Tractors I've ever seen the decks were painted the same color Yellow as the Tractor. I have 3 B series decks, and their all original and in Yellow. Not sure about the 900 series fitting the B series. Good possibility. Someone more knowledgable can jump in and tell ya...
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 10:38am
The size of the center pulley on the 900 Series deck may be different. If so it will run a different speed. You cannot put a 900 Series deck on a B-10 or B-110 because the height adjusters will hit the rear tires but the B-112 has a longer wheelbase so a later deck will still physically fit the machine. You might be able to change out the pulley. A homesteader deck would be too small, only 36" and the front hitch points are different.
