hard valve seats
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Topic: hard valve seats
    Posted: 06 Apr 2010 at 4:20am
I've got the heads off my 25-40 Threshermans Special at the moment. The valves need grinding in, but those seats are hard suckers! Anybody know what kind of compound will cut them?
Tricky Dickie
PaulRoidt(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulRoidt(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 7:46am
Tricky,
I would grind the valve and dress the seat with a seat grinder.  Then lap it in with some lapping compound.
If you are trying to just lap them in, it will take a long time, especially if they have any amount of wear on them.
Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 11:01am
Thanks Paul, I think that will be the best way forward as I'm getting nowhere by just grinding with paste.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulRoidt(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 12:01pm
Are your arms sore?
Paul
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 12:53pm
No where is where anyone really gets trying to do a valve grind with grinding compound. Some where over time the reason for lapping got mixed up with the actual grinding of valves and use of the lapping tool.
I have the hand equipment/tools used to face valves and cut new seats on Model T type engines. I need to take some pictures of them. After looking at the pictures of how it was done it is easier to understand why it was necessary to do quite a bit of lapping.
It would have still been after facing valves and cutting seats with what they had to work with at the time.
Also could be that in watching the lapping done and not the first part that some could get the idea that lapping was all that was done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 1:02pm
I don't know for sure, but they may have put hardened seats in it from the factory. All of my oldest Wisconsin engines from the 40's have hard exhaust seats in them. Sometimes they have a Stellite exhaust valve too. If there's any real wear, just bite the bullet and have them ground.
Edited by Brian Jasper co. Ia - 06 Apr 2010 at 1:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 1:08pm
I'll add to what Dick says in that when I grind valves for my small engines, I find that I can get a better seal, plus the location on the valve face can be seen so I know if I need to widen or narrow a seat when I lap them in when done. The tools aren't cheap, but that's what it takes to make them seal. Another reason to take the heads in is if the guides are loose, they can be knurled to restore proper valve control. Sloppy guides will beat the seats out of round and then they leak.
I got lucky on evilbay and bought an old Sioux valve grinder and hard seat grinder very reasonable. They're old, but still work well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 1:10pm
Dick, are your Model T valve tools hardened cutters run by hand and not stones?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 1:15pm
Yes, run by hand and no stones.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 1:36pm
Valves and seats need to be ground with a valve grinding machine then lapped in for the smallest margin. IF you have a seat thats being aggravating to remove and you want to remove run a heliarc ring around the seat it will fall out. welding causes metal to draw.
Edited by mlpankey - 06 Apr 2010 at 1:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 2:12pm
Tricky,
Are the seats inserts or just part of the head?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 7:32pm
The seats are replaceable.  Typically the seat is ground for uniformity and the width of the seat determines the ability of the valve to transfer heat to the head. Water cooled engines are not as critical as the air cooled cylinders. The use of Prussion blue to determine seat uniformity and width is of great help. Once the seat is uniform, center of the valve face 25-30% of the width of the face of the valve, lapping compound will provide a great finished product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 12:04pm
The seats are replaceable and are made from some alloy steel which is ultra-hard. Thanks for all your advice guys; I think that I will have them recut professionally.
Tricky Dickie
