GMC truck
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Topic: GMC truck
    Posted: 05 Apr 2010 at 8:52pm
I had some trouble with my truck this weekend  its an 02 GMC duramax 2500. When I shut it off it wouldnt start '' like the batteries where low or starter was bad''  well they are new batteries and i put a new starter in it saturday mornin. The starter chatters when you try to start it like there is not enough juice   but if you jump acrossed the starter with a screw driver and turn the key at the same time it will fire right up.  Has anyone else had this go on before?
      Shawn
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 10:17pm
Bad connection on either a ground or the starter solenoid from what it sounds like. Dads 04 had the same thing after he put a new starter on it and it turned out the positive was a little bit loose on the starter, made it sound like weak batterys starting it, and thats when it did start.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 12:48am
try this site, it's the best one I found
http://www.dieselplace.com
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
This page was generated in 0.248 seconds.
