Trick to taking out spring pins on deluxe seat
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Trick to taking out spring pins on deluxe seat
    Posted: 05 Apr 2010 at 8:21pm
Was going to try and take the seat apart on my D17 as all the rubber grommets and bushings are all worn out.  Anyone have a trick to removing the spring pins out of the three spots so I can drive those 1/2 rods out to dissassemble the seat.  I tried to drive them out with a punch and they just mashed over.  I tried to drill them, but because they're hardened.  I might as well move the seat right next to the bench grinder as I will be sharpening drill bits for eternity.  Was wondering if someone who already took theirs apart found a trick to it?   Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:33pm
Chuck - no real "trick" that I know of...btdt... soak them in PB Blaster, etc. repeated for a long time first.  Just cut them off flush on both sides so the don't mash over and use a very good punch and a BFH...when they don't budge, soak some more, give some more time and come back another day and repeat...its what it took for me.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:45pm
Thanks Mike.  I will give them a soaking tonite.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 9:40pm
Chuck, try using a roll pin punch.  It has a tit in the middle of the punch to keep it centered in the roll pin.  Less chance of mushrooming the roll pin.  You can get complete sets of roll pin punches or purchase them individually from your favorite tool salesman.  Got mine from Snap On.  They work really well.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 9:56pm
Forget driving the roll pins out....take a big hammer and punch and drive out the 1/2" pins while shearing off the roll pins. If you then want to attempt to drive out the roll pins, they may cooperate, but I usually installl new 1/2 pins and tack weld them in place anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 10:49pm
It is best to support the workpiece against a solid surface. Use a short drive pin punch to get the pins started. Then use a longer one to finish removal. HTH Tracy Martin
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 8:47am
I've saved several hours in several places on 45's with roll pin punches, you must hit a solid surface, wise investment.
http://www.thetoolwarehouse.net/p-5802-sk-hand-tool-6069.aspx
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
