Baler recommendations for 190 gas |
Post Reply ![]() |
Author | ||
Brian-KS ![]() Orange Level ![]() Joined: 27 Aug 2014 Location: Kansas Points: 914 |
![]() ![]() ![]() ![]() ![]() Posted: 19 May 2015 at 11:24am |
I'm looking for suggestions for a USED baler that makes big round bales that I can use behind my 190 gas tractor (76 hp @ PTO). I'll be putting up close to 100 bales this year. I'm looking for something on the lower end of the price range. Maybe a Massey 1560 or Vermeer 605f?? Maybe not?? I have seen mixed (mostly bad) reviews about the Deere 510.
Any suggestions?? Do you know of a good one for sale?? Edited by Brian-KS - 19 May 2015 at 12:20pm |
EAT BEEF!
Sponsored Links | ||
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
It seems to me that most of those balers specify a 100+ HP tractor. I could be wrong. No doubt you'd want a smaller capacity big baler.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8716 |
I put my 660 new Holland behind my one ninety gas for a short time, and it was definitely too much baler for the tractor. I would imagine that any 5 X 6 baler would pull equally as hard, so I would say that you will have to go to like a 4 X 5 or smaller baler. Guess if you weren't in a hurry, didn't have the bale density too tight, and had all flat ground, then you could probably do it. Darrel
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
We ran a 605 F behind a 190xt Diesel for years didn't have any problems, if your ground is flat, and no more than 100 bales a year, I would just plan on it. I know the gasser may not lug as well, so you could have issues in non ideal conditions, but I would think you should be fine.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29805 |
Dad pulled a 1500 Gehl for years with his 190XT gasser with no problems. He custom baled thousands of bales with it. A 1500 I think is similar in size to a 605F.
Wink I am a Russian Bot |
There is a huge difference between a one ninety gas, and an XT diesel. The same 660 new Holland that my one ninety gas struggled with, my XT diesel toys with. Darrel
About 13 horsepower I think. |
EAT BEEF!
Thanks for the replies guys! Sounds like a Gehl 1500A or a Ford 552 (same thing only blue) would be my best choice.
Has anyone here had experience with a Hesston 5545 ? Would that be a good one for my 190? It's a 4x5 baler. If anyone knows of one for sale, please let me know. ![]() Edited by Brian-KS - 19 May 2015 at 7:10pm |
EAT BEEF!
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
tractor house has 2 1500a for sale at ag land implement new hampton ia. $900 ea. also a 1500 for sale in arkansas for $2500.
albion equipment in ill has a 1500 for $1500. ph 618-445-2393
gerkendave ![]() Orange Level ![]() Joined: 08 Jul 2013 Location: York, Nebraska Points: 568 |
I have an xt diesel and purchased a Hesston 560 on Big Iron a little over a year ago for 900. (yeah I know not that many can be had that cheap) but the nicest thing is the bale kicker (no backing up required when dumping a bale). There are quite a few 560/565 or case 8460/8465 balers that sell on Big Iron for a cheap price. As a matter of fact there is one going off tomorrow that looks nice but sits in Nebraska.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2296 |
I pulled a Vermeer 605C for twenty years with a 706 IH gas, I thought it was about a perfect match, about same hp as your 190 and I did 600 or 700 bales a year.
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 781 |
We have ran a New Idea 484 4x5 round baler behind our 190 XT3 diesel. It mostly played with it but a gas may have been a different story. our 484 has been a good baler.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
DaveCinIN ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Kouts, IN Points: 629 |
I use a 5X5 Hesston behind the XT gas at one of my hay fields.
AC 7045
AC 190XT with Gleaner L engine Hesston, New Holland and New Idea hay equipment OK, so what's the speed of dark? |
VFDfireman ![]() Silver Level ![]() ![]() Joined: 11 Jan 2013 Location: South Dakota Points: 414 |
We ran a 605C behind a 706 IH diesel as well and later a 605H baler. Ran both balers just fine. |
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 404 |
We use a JD 385 that makes 4x5 bales. We have pulled it behind a 175 diesel, 6060, and 6070. No issues with any of them.
Probably is 13 HP on paper, but in actuality, the difference between a non-XT gas, and an XT diesel is quite a bit more. Darrel |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
My series 4 D17 diesel turns out around 70 hp. it runs a NH 851 round baler well. If you can find 1 with new chains they will serve you well. They do not make a good looking bale.
Thanks for all of the information and recommendations! The search begins
EAT BEEF!
Should have watched that one of big iron today was a Hesston 565a with new belts last year, thing shined like a shed kept baler. Only went for 1450.
ACfarmboy24 ![]() Bronze Level ![]() Joined: 19 Sep 2011 Location: New York Points: 117 |
You should be fine. My neighbor runs a 180 diesel on a 4x5 NH 648. Runs it pretty well too. The only reason though is because his 6080 blew an engine and is in the shop.
AC 200, AC 7045, NH 4630, White 508, CIH 5600, Athens 76, AC 333, Hesston 545
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9880 |
I used to custom bale with a 180 diesel and a Vermeer 605 baler.
Post Reply ![]() |
