wiring diagram for Ca
Lincoln View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lincoln Quote  Post ReplyReply Direct Link To This Post Topic: wiring diagram for Ca
    Posted: 05 Apr 2010 at 1:16pm
Does anyone have a wiring diagram for a 1951 CA that they can post please?
Thank you,
Lincoln
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 1:38pm
Is it still a magneto or does it have a distributor? Go to Duey Schutter's wiring diagram page. Here is a link for 12 volt conversion.
http://dueyschutter.freeservers.com/photo3.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lincoln Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:34pm
Thanks for the link, however our unit is the original 6 volt positive ground. Any help would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 10:13pm
The B and C wiring diagram is the same as the CA. It is down toward the bottom of the page. If you still have the magneto that is. If you don't have a mag you would have 6volts going to the coil instead of a grounded kill switch to the mag. Everything else is the same.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 10:15pm
Still need the diagram?
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 9:47am
Here's picture of a wiring diagram I found on the side of my 1948 model C battery box after I started stripping paint. Hope it helps.
This page was generated in 0.119 seconds.
