How fat of a rear tire will fit WDs?
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Topic: How fat of a rear tire will fit WDs?
    Posted: 05 Apr 2010 at 10:38am
I've got a rear tire that is totally shot with a huge tear in the sidewall.
What is the widest rear tire that will fit a WD without rubbing the fenders?  Also, any recommedation on a tire that pulls good?
Thanks in advance...with any luck I hope to have it running again asap.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 4:06pm
I've got 18.4 x 26 on one. If you spun the wheels out or had a deep offset you could go wider. The only problem you will have is wheel width, but you could go 20.5 if you had the right wheel combination.
I'm not sure what size these are, but they are MONSTERS!
Edited by John (C-IL) - 05 Apr 2010 at 4:10pm
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 4:18pm
Mine has 14.9's on it
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 6:54pm
We,ve got 16.9's on 14" rims pulls good.. We've also had 16.9's on a 13" rim and it would'nt pull itself off the trailer.. Like John (C-IL) said, it depends on your rims.
