ac wd45
achk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote achk Quote  Post ReplyReply Direct Link To This Post Topic: ac wd45
    Posted: 16 May 2015 at 5:01am
Can anyone tel me how to install the governer in combination with the carburator from a wd45?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2015 at 11:36pm
I'm not sure I understand your question, so I'll ask a question which I BELIEVE you may be asking:
How does one assemble and adjust the carbeurator-to-governor linkage?
Is that what you need to know?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2015 at 6:29pm
Of you're trying to adjust your governor. Once you hook up your linkages, woth the engine off put the throttle to its max. Pull the trotter linkage from the carb to the governor arm at the governor arm end. It should be able to easily slide in and out or even be up to an 1/8 of an inch short. If it's too long, bend the throttle arm to make it shorter. Easy peasy
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.168 seconds.
