Simp Sun Runner Controls
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: Simp Sun Runner Controls
    Posted: 12 May 2015 at 8:36am
The throttle and shifter  have a tendency to drift to less throttle  and  speed,  is this normal or is there a way to tighten them  so they stay in position ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 6:59pm
Inside the steering column are the pivot bolts for the levers and they will loosen up over time. Have to tighten them on mine every once in a while. Just don't want to get to snug as you will want them to move easily.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 8:37pm
i thought that, but like other opinions before i charge in.Thank you.  the fun   i mean sun runner is fun to use , and cuts almost as well as my sunstar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 7:23pm
opened the column, found the nuts and tightened them,  looks like it works beautiful. thanks for the help.
This page was generated in 0.168 seconds.
